Storefront Mullion Join Issue
    Why does this happen? I am trying to fix this storefront, and the horizontal mullions are crossing into the vertical. I have seen this happen before but I am not sure why it happens. Please see attached image.
    It's hard to assess "why" without seeing how it was modeled, but the fix could be as simple as toggling the join condition. Did you try adjusting by "Make Continuous" or "Break at Join"?
    Jon
      I think that this happens due to either having mullion profiles that don't have matching centers and/or faces. It may also be due to an edit to the curtain wall profile. Try doing a copy/paste of that curtain wall and do a Profile Reset on it and see if that fixes the issue. But as Jon mentioned it's hard to tell exactly what is happening without having the curtain wall to check out.
        Could also be a graphics card issue. Does it print like this?
        Greg McDowell Jr
        about.me/GMcDowellJr
