BIM 360 Design & DWG Links
    I'm using BIM 360 Design (not C4R) in Revit 2018.3.1
    I've got a DWG link that I uploaded to the same folder in BIM 360 Docs
    The DWG was originally located on our network drive, and that's what the path still says, so of course I'm getting a "File not found" error.
    Here's my problem: When I go to Manage Links, I can see my BIM 360 drive under the Revit Links, but I don't have that drive under the CAD Formats tab.
    So, how do I repath my DWG?
    Dave Plumb
    BWBR Architects; St Paul, MN
    Im not 100% certain, but i thought you had to do it through Desktop Connector? Or did they change it?
      I have Desktop Connector installed, but I'm not sure it's working right.
      It doesn't start on boot. I have to start it manually, and half the time when I start it, I get the Event Viewer popping up. :crazy:
Name:	ADSK Connector.PNG
      Dave Plumb
        Did you install the latest version 6.1.0.667? If you installed an earlier version, one must install two programs: Desktop Connector 6.0 and the BIM 360 plugin B360provider.exe.
          Yup. I've got 6.1.0.667 installed.
          I've also noticed that it's pretty bad at shutting down.
          Seems to often take a long time, or never close at system shutdown
          Dave Plumb
            Forgive me for asking the obvious, but you already have access to the new BIM 360 hub? I installed the Connector on our Citrix servers, and had difficulty with one server. Connector would crash whenever it tried to load. Autodesk was able to resolve it - my Windows Profile was at fault. I don't think this applies to your case; however I wonder if it will work on a different computer?
              Two months (and a couple of versions) later I just stumbled across my old post.
              We're now on Desktop Connector 6.3.0.692 and things seems to be working much better.
              Dave Plumb
                Hey Dave...so are you able to link in a DWG that is on the BIM 360 drive? If so...what did you do? I can see the dwg's via the desktop connector in explorer but nothing when I try to link a DWG file from Revit. If I have to download the files and work locally BIM 360...well...it s$#ks.
                Revit Import/Link shows the External Reference Cloud connection....but nothing on the CAD side. :/
                  Okay...got it to work. Turns out our IT guy disabled Network Discovery on all our workstations. So I had to drag and drop our BIM 360 share folder to my desktop so Revit could see it.
                    Good to know. Tons of offices disable Network Discovery.
                    Aaron Maller
                    Director
                    Parallax Team, Inc.
