I don't know what's going on - and i am about to rip my hair out.
Our IT Staff updated our firm's PC Image, uninstalling Revit 2015 and installing Revit 2018 (including the 2018.3.1 hotfix/update), as well as modifying the Revit 2017 install to include the 2017.2.3 update.
However when they run the image, They are getting a pair of pop-up errors related to an older version of dynamo (see attached).
I have tried installing Dynamo 1.3.2 prior to running the Revit install - since that is the version that is included in the Revit 2018.3.1 Hotfix - hoping that , if the proper version of dynamo were already installed, it would skip the dynamo related updates within the hotfix....
No Dice.
I got the same error messages during the subsequent Revit Install.
I then deleted all traces of all versions of Dynamo and 2018 versions of Autodesk products from a test machine (including all registry data, and program cache). As far as the test computer was concerned - it was a clean slate with regard to Dynamo and Autodesk 2018 products.
No Dice.
I got the same pop-up error messages during the subsequent Revit 2018 install - during the Hotfix install.
BIGGER ISSUE - this isn't just about Dynamo - whatever is going on, is causing the installed versions of Revit, to not be able to utilize BIM360 Design (formerly, "Collaboration for Revit"). The Collaborate button is missing from the Collaborate Tab, and there is no BIM360 "place" listed along the left side of the OPEN dialogue window (and yes - i was logged in to Autodesk with my ID, and i have permissions for BIM360 Design).
I am at a complete loss - I am not sure what exactly went wrong, or how to make it right.... People who's PC's are based on an older image are not having this problem. Revit 2018 + 2018.3.1 install without a blip.
Anyone have any thoughts?
No Dice.
No Dice.
