I am able to make pressure drop calculations for standard straight ducts and pipes, and i've worked out how to do them for elbows.
Still, the t-fittings (or any fitting with more than 2 paths) remain blank, as for pressure drop. No setting at all will change the blank section.
Can someone help me with calculating the pressure drop in multiple-path fittings in pipe/duct systems?
Kind regards
Kind regards
