Hi all,
Coordinates in Revit have always been a bit of black magic to me... hoping someone has an easy answer to this...
I've got a site model and a building model, each linked to each other. Each file has the exact same property lines of the lot (the same one I was having "issues" with last week
). I moved both the survey point and project point to the same corner of the property line in each file, and relocated everything so all coordinates read 0, 0, 0.
If I link a file into the other, and select to use shared coordinates or project base point for positioning, the property lines line up perfectly. So far, so good.
Here's the issue though... if I draw a filled region in one view (e.g. site plan) of the building model, and then copy and paste to the site plan model, it does not paste in the same spot relative to the property lines. Is there a way to make it paste in identical locations?
If I use "center to center" or "origin to origin" for the positioning when linking the model, it comes in exactly the same offset as when I paste my filled region... so obviously there is still some sort of internal coordinates that are not aligned in each model.
I've been messing around with acquiring and publishing coordinates, but my brain is a little too small to "get it". Does it have something to do with that, or is that the wrong track?
Thanks!
Thanks!
