I know (hope) this there is a simple answer for this issue. I need to find out if there is way to organize the sheets, in the browser (not the sheet index), by any other options than the ones given. I have "A" sheets and "C" sheets and I would like the "C" sheets to be listed before the "A" sheets. Any information is already appreciated. Thx!
sheet browser organization..
Create a parameter (number or letter) and assign to the sheets category (Instance)...assign all of your C Sheets to be A or 1 and the A sheets to B or 2...sort by that parameter ascending.
Do the same thing for Civil Sheets that don't want to follow the alphabet.Michael "MP" Patrick (Deceased - R.I.P)
Originally posted by MPwuzhere View PostCreate a parameter (number or letter) and assign to the sheets category (Instance)...assign all of your C Sheets to be A or 1 and the A sheets to B or 2...sort by that parameter ascending.
Thank you for responding. My inquiry is a little different than organizing the sheets for the index... When I print multiple sheets as a combined pdf, the sheet order, (in the pdf printer dialogue), is organized alphabetically, which causes an additional step of re-organizing the sheets so that the cover sheet and other "C" sheets are at the top of the document. I am curious if there is any directive in Revit that can adjust this alignment? Now that I am writing this out in more detail, I guess, I may need to look at the capabilities of pdf program. Thank you both for responding.Thank you!
Ledo
Rather than a single digit, we assign a 3-digit number to our Sort Order parameter.
That way, if everyone (consultants) follows our standards, all they have to do is assign all of their Sheets to their "hundred" series.
100s - Front end
200s - Civil & Landscape
300s - Structural
400s - Architectural Plans
500s - Arch Exterior
600s - Arch Interior
700s - Plumbing
800s - HVAC
900s - Electrtical
The 2nd & 3rd digit ("tens" and "ones") are the Floor # (we rarely get above 09)
Any other organization can be done within the 2rd & 3rd digits any way they want.Dave Plumb
BWBR Architects; St Paul, MN
Originally posted by Ledo View PostThank you for responding. My inquiry is a little different than organizing the sheets for the index... When I print multiple sheets as a combined pdf, the sheet order, (in the pdf printer dialogue), is organized alphabetically, which causes an additional step of re-organizing the sheets so that the cover sheet and other "C" sheets are at the top of the document. I am curious if there is any directive in Revit that can adjust this alignment? Now that I am writing this out in more detail, I guess, I may need to look at the capabilities of pdf program. Thank you both for responding.
Originally posted by DaveP View PostRather than a single digit, we assign a 3-digit number to our Sort Order parameter.
100s - Front end
300s - Structural
700s - Plumbing
800s - HVAC
900s - Electrtical
Any other organization can be done within the 2rd & 3rd digits any way they want.Which Direction Will You Choose?
Hi - I'm having trouble getting our sheets to sort in the sheet browser in the correct order. I've attached some screen shots and we've already tried...April 24, 2014, 06:41 PM
So, here I sit on the weekend toiling away at updating our sheet index (need to add ~400 sheets to it). Is there any way to quickly replace text in multiple...September 21, 2014, 06:43 PM
Anyone's thoughts on whether those come in handy or not? I've seen a few at this point that let you create a new sheet one by one. I had put together...
Channel: Third party Add-Ins, API and R&D
June 3, 2011, 02:43 PM -
We have sheets that don't follow the typical A101, A102, etc. We have a letter before the number but it's not arranged alphabetically....October 5, 2015, 08:18 PM -
Hi
I am trying to add a Bar bending schedule onto a drawing sheet. I have seen on other drawings that a sheet can be added below a sheet...-
September 27, 2016, 10:27 AM -
