Does anyone know how to get an existing door to refer to the new rooms rather then the existing rooms when exporting to COBie? It appears it only refers to the rooms it was built in (existing) but I need them to look for the new rooms in the component.space field.
COBie Space Issue
For anyone else who runs into this issue, the workaround I went with was detaching the model and saving it locally. Then any elements that needed to be referencing new rooms I changed their phasing from existing to new and exported COBie from that file.
Am still working on finding a better solution but this will work for now.
I ran a test for a multiple phase project including 4 plus phases today. The final test I ran is to combine all phases into one for the final model submittal...March 25, 2016, 12:42 AM
Our current project includes tracking existing rooms within a demolished area. I found this post on Revit OpEd, and was wandering if this is the best...January 4, 2016, 11:25 PM
Currently, for our TI sheets, we will create a view that includes existing room elements and tags and nothing else to place over the top of the renovation...July 22, 2020, 03:04 PM
If you've seen a demo of Revit MEP and Spaces or if you have used Spaces yourself then you may already be familiar with the new Rooms version of Place...
Channel: Blog Feeds
April 15, 2015, 05:15 PM -
Hei,
I have notice that I have boundaries around rooms, but I don't know where I can disable visibility of them, could anyone help?...September 9, 2019, 01:02 PM
