Hi
I am working on a project that requires all the connections to be modelled, So I am busy using the structural connections tool in revit 2018, The problem is whenever I make a connection revit seems to forget it, That is if I have say 10 splices, shear connections, base plate that are the same or even similar to model I have to repeat the process of inputting the data each time almost for each one, they do copy around the same component, but still, how can I create customised connections. I want to input the data once, ie make a 360uB51 splice and every time I need to splice that guy I just click on the same connection type.
Any help greatly appreciated.
Thank you in advance
