Spot Elevation in Family to read level in Project
    I've searched through the site to try to find an answer but can't find exactly what I'm looking for.
    Is there a way to add a spot elevation to a family to fill an instance parameter within that family when loaded into a project? To expand, I've built a below slab drainage manhole family from which I can create a parametric manhole schedule which reads the various levels and sizes of the manhole and schedules them out for the contractor to follow, which works exactly as I want. The down side however is that I have to manually enter the cover level of the family into that parameter, the various other levels I also need are simply dimensioned from that level but it's annoying that I have to place the family at the correct level and then manually type in the cover level to that parameter.
    Is there anyway I can have the family fill in it's own cover level parameter from the level which it is placed in the project. If there was an option to add a spot elevation in the family editor to my manhole family which then gets occupied once the family is loaded into a project that would be perfect, but that doesn't seem to exist. For example, if I could spot elevate the cover level of the manhole in the family editor and I dropped the family in the project with the cover at 10.5m above datum the cover level would return +10,500, then if I moved the family up by 150mm the parameter would automatically return +10,650, that would be ideal.
    Any help or suggestions would be really appreciated.
    Thanks!
    Bump Up.
    I'm looking for something similar.
    Any experts out there who can help?
    Please..
      Don't think there is a way for a tag or generic annotation to read the placement height of a family, either in the family itself or in the project.
      What you can do is ad a parameter to the family that changes the Placement Height. Meaning that the Elevation (in the properties panel) would always be 0 and there would be an extra parameter named Placement Height for example. This is a parameter you can read with a Generic Annotation inside the family. BUT this would be from the level the family is on, so not from the project basepoint.
      You could also ad a generic annotation to the family that reads a parameter you fill in by hand or with Dynamo if you want to automate it a bit. But you would have to run the Dynamo script every time the Placement Height of a family changes (or if it is just one change it by hand), which could end you up with wrong data if that is forgotten.
        Thanks for the reply.
        How about this.
        When I place a family and place a spot elevation on the top of it, a certain elevation value is generated.
        What i'm looking for is to place a parameter into the family, and when i key in say, 107.85, the family is placed at that elevation's value.
        hope my question is not confusing.
