Colors of IFC
    Colors of IFC
    Is there any other method to color the color of the output, other than material?
    I'm looking for a simple tool or way to force rebar diameters into colors.
    Thanks
    You can edit dimension in type properties and make changes as you want.
    I am Sure you got all dimensions in color as you assign. also check settings of IFC in Application.
    Find Image for more details.
    Thanks & Regards,
    Hitesh C
    BIM Engineer
      Thanks for reply
      What i meant was .. i want certain elements to color in the IFC export.
      Main use : rebar diameters in different colors
      Answer: not possible with Revit. IFC import export with other software.
        Revit to IFC
        Originally posted by HansLammerts View Post
        Thanks for reply
        You mean IFC Import & Export with a different colour is not possible in Revit. Which software support us to complete our requirement?
        Thanks & Regards,
        Hitesh C
        BIM Engineer
          Yes, that indeed is one of the questions for getting better Exports from it.
          Here is more about that discussion from a IFC fileformat point of view. It has an open end..
