I am not sure how to word this the best way. Basically, is there a way to change the height of all of the room boundaries at once? I am working on an RCP and some of the rooms aren't tagging. I figured out that it was because, in section, the room volumes in some of the areas, weren't going all the way up to the ceiling. Is there a way to change them all together so I don't have to make sections for each area and adjust rooms individually?
Change the room volume Height for Rooms in Revit
Originally posted by katewood1989 View PostUnfortunately not, which is a bummer
No need to make a Section View, at all.
for some reason my rooms are not finding the ceilings. I've checked the volume setting is on. The ceilings are room bounding. Any ideas? Is it cause...May 18, 2016, 12:53 PM
If I place a room that spans multiple levels, for example for an elevator, is there a way to make it add the area for that room to each floor that it...May 27, 2015, 07:49 AM
We have some rooms that have automatically found the ceiling height, but others that don't. Is there anyway to force revit to recalculate the room heights...February 27, 2018, 02:32 PM
I have a co-worker who is trying to place rooms in his model and he keeps getting a message saying "A Room's Upper Limit must be above its Base...October 3, 2016, 06:26 PM
How to connect more rooms so it will show bigger area even though they are closed. In my case i want to join red marked rooms into above one....April 21, 2011, 10:21 AM
