Double line and single line pipes based on size?
    I just received a request for Revit to show double line pipes based on size of the pipe.
    First I said, No that's not possible, but then I was thinking of a workaround to accomplish this, maybe filters, but that's a no go...
    Has anyone tried to show both single line & double line pipes in the same view based on pipe size.
    4" pipe size and larger to be double line.
    Thanks in advanced!
    Nope, not possible. I've seen some people suggest overlapping two viewports with different filter settings but f that noise. I usually do my best to accommodate requests like this at my office but in this instance my answer has been a succinct "Nope."
      Pipe placeholders are single line only, you could draw with those for the small diameter piping.
      • single line display issue
        OK i have rises that in single line view show as 3/4" round with a line. the only way i have been able to get them to show proper is to extend the...
        July 9, 2012, 01:43 PM
      • Heat Trace Pipe
        Need to show heat trace pipe on existing pipe. Anyone have a good way of showing this? The heat trace will also have to stop at some walls. I'm guessing...
        December 28, 2015, 11:52 AM
      • pipe symbols in medium and corse view settings
        Where i work the revit department has been asked to make all pipes at 1/8" scale and higher show as single lines with fitting tic marks moving with...
        September 4, 2015, 02:36 PM
      • Single line pipework layout
        I am trying to do a layout of my pipework in single line for my drawing sheets.
        i have managed to set up some filters setting colours and single...
        October 9, 2015, 11:55 AM
      • Why when i draw pipe it shows single line ??!
        Hi, it is strange when i draw pipe with diameter it shows line (Image attached)?!! why i saw this also when i tried to make layout for cooling tower with...
        May 18, 2012, 07:41 PM
