Well I'm struggling with Revit 2018.3, there are a lot of things going bad since I've started to use it, today Stairs by sketch don't want to work at all.
I'm drawing a normal monolithic stair (see image) in the same way i always do by using stair command and nothing happen, I have only that Dialog box that says: Revit isn't able to create the stair and my options are : A) erase the stair or B) Redraw the stair
well I've already try to re draw the stair multiple times with no luck, I've already re draw the stair in the editor mode with no luck either, and if I try to change the stair type that don't work :banghead:
Have you seen this before? is very annoying
