is there a way with Dynamo to control the size of a callout boundary? Also, and the leader direction and callout head location be altered with Dynamo?
Callout boundry and callout leader direction and callout head location?
From what I've found it is only possible through the API: https://forum.dynamobim.com/t/refere...y-curves/14779
Maybe some of the more Dynamo savvy folks might chime in with a better method? :thumbsup:
Originally posted by cellophane View PostFrom what I've found it is only possible through the API: https://forum.dynamobim.com/t/refere...y-curves/14779
Maybe some of the more Dynamo savvy folks might chime in with a better method? :thumbsup:I'm interested in two results, #1 being able to set the callout boundary size and shape for multiple instances, and #2 be able to control the location of the callout head in relation to the callout boundary. The standard location is pointing in the 0 direction. That's OK for my section detail callouts but for plan view callouts I want them all pointing up (90). Sometimes I have lots of them and it's a PITA to have to manually move the callout heads for each individual callout instance. If I can get confirmation that these options can be accomplished somehow with Dynamo, Python, or whatever I'll then pay someone to create the programming.
So, the good news is, you can modify the crop regions with the attached DYN. There is also a GIF of it in action.
For the location of the elbow and bend of the bubble, I am not sure that is accessible in the API unfortunately. (At least I couldn't find it :hide
Hope this at least helps with some of it though! (Note- The python scripts in the file are remixes of stuff in the MEPOver package)
https://drive.google.com/open?id=1dv...b9T3lBgBIpNG05Attached Files
John Pierson
Creator of Rhythm, Monocle, Bang! and Lots of Other Okay Stuff.
Twitter - @60secondrevit | Email - [email protected] | Blog - designtechunraveled.com | Biobio.link/johnpierson
Originally posted by johnp View PostSo, the good news is, you can modify the crop regions with the attached DYN. There is also a GIF of it in action.
https://drive.google.com/open?id=1dv...b9T3lBgBIpNG05I'm retired, if you don't like it, go around!
I am transitioning from Autocad to Revit. I've been round and round through the "help" menus like it's Groundhog Day, but still don't understand...November 22, 2011, 05:27 AM
Just as the title says. Is this possible? I'm wanting to have multiple Callout Bubbles to references Archs, Mechs, Elec, etc all on a general site plan....July 2, 2013, 04:20 PM
I am fairy new to revit and was wondering if there is an easy way to clip out (see jpeg) the portion of the callout graphics that is outside my cropped...February 9, 2018, 02:16 PM
Is it not possible to have a callout represented on multiple views? If not whats the best workaround? I have been using masking regions but its not fun...July 26, 2011, 08:23 AM
Hello to everyone,
I am at the moment trying to understand why is the callout section head rectangular or where can I change that. You can...-
December 7, 2018, 01:56 PM -
