it would be nice if it was possible to do sheet references (for notes) and am wondering if this is in revit and I just haven't discovered it yet or if others have figured out some work-around? or do it the old fashioned way.
is there a way to do sheet references similar to how you do a view reference?
To my knowledge there is not a way to do a sheet reference.
One way to achieve what you're talking about would be to put the notes in drafting view, put the drafting view on a sheet, and then create a view reference that only contains the sheet number, rather than the detail number + sheet number.
That said, I'm not sure if that is really a workflow that makes sense to adopt... have you investigated keynoting or note blocks as a way to achieve the desired end?
Originally posted by ebordenave View Postit would be nice if it was possible to do sheet references (for notes) and am wondering if this is in revit and I just haven't discovered it yet or if others have figured out some work-around? or do it the old fashioned way.
open the OOTB view reference family, SaveAs, and change the label text to match the height, width, and style of your project text. In the project type your text and where the view ref goes create some spaces and create the view ref there. Takes a little bit of tweaking but when done group the text and view ref so they don't get separated. If you don't want the detail number just delete that label in the family (and delete the slash). Granted, not the most in tune way to create a reference but it beats the heck out of having to keep track of text detail references!I'm retired, if you don't like it, go around!
Does anyone use a clever way to link a full sheet reference with project no. prefixed into a note.
e.g. For general notes please refer to...July 5, 2013, 12:02 PM -
Previously when inserting a view reference (ribbon - view - sheet composition - View Reference) the detail number and sheet would be listed alongside...January 31, 2017, 09:36 PM
Hi All,
When creating a new viewport (not a duplicate) Revit is referencing it to another sheet/viewport that is not relevant at all.
The...March 31, 2014, 01:24 PM -
Looking to find out if revit has a feature where you could back reference the view from where the details are cut? We have a client...April 15, 2016, 02:25 AM -
View Reference tag that can display a view's name too not just sheet and number data?
Also tried adding a shared parameter to the View Reference...February 16, 2015, 10:18 AM
