I have had the same issue happen a few times and just ignored it and it seems random. We are a mechanical contractor and when I get Revit models I copy the M & P models to use as my working models. I like to link in the originals and leave them in a closed workset. The weird thing is that sometimes it will not let me link in the original model and gives me an error that the linked model is the same as the current model. Is there a way to fix this?
M & P Links
So your model has the same GUID as the MEP model?
Do you just copy/rename the file before you start using it? Or open it with Detach from Central and then save as a new file?
If you do that you shouldnt have this problem."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Originally posted by josephpeel View PostSo your model has the same GUID as the MEP model?
I always do detach and save as central, partly because we put them on a revit server, but also because it cleans up temporary stuff and reduces the size a bit.
If use Reload From you should be able to re-link without any problems."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
I was able to get the Original Mech Project loaded into my working project. The weird thing now is that it is only showing up when I have the Plumbing Workset turned on. I can put the Original Mech on any other Workset and have it turned on but as soon as I turn the Plumbing Workset off it hides the Original Mech link. I am really confused by this.
You can put (multiple) placed instances of a link in (different) worksets if you wish, but the link 'Type', or linked file, itself is also in a workset.
Go to the links at the bottom of the project browser, select Type Properties. The linked model itself, rather than its placed instances, is probably in the plumbing workset too...
(For example I worked on a datacentre project with 10 identical buildings. It was 1 link, placed multiple times, with worksets for the different buildings)Last edited by josephpeel; June 28, 2018, 10:26 AM."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Originally posted by josephpeel View PostYou can put (multiple) placed instances of a link in (different) worksets if you wish, but the link 'Type', or linked file, itself is also in a workset.
Can anyone help with this problem.
I have received a new model from the architect and I want to use the 'reload from' from function in manage...September 16, 2016, 03:04 PM -
Hello all,
I have a curious question about linking models in Revit. Does it matter if the linked model is a central file or not? What would...May 14, 2020, 04:36 PM -
What's the best practice for sending a model to consultants when the file is workshared? We haven't been using worksharing very long and are at the point...October 18, 2012, 05:22 PM
Friends i am a newbie in revit, My problem i have received a package in CD from counsultantant, its a big project, when i open any file the message appears...January 5, 2015, 10:59 AM
I have an architect issuing us their architectural model.
Good stuff. The model, like ours is a multi set model. i.e it has a central...January 18, 2012, 03:57 PM
Monumetric Footer In-screen
