Simply Complex: If you want points to be evenly distributed across your Dynamo surface consider using List at level as shown in the image below in lieu of cross product lacing.
List at level could replace using cross product lacing in some cases. Its best if you try it for yourself and decide when it is right for you to use list at level. Good luck!
