Building Coder: REX SDK Templates for Revit Structure 2019
    Apparently, the Revit SDK REX Visual Studio templates are obsolete.Let's fix that problem.Also, two little notes on a C# optimisation trick for math-heavy code, and the current status of the Forge Design Automation API for Revit Revit Structure 2019 REX Extension SDK Visual Studio Templates Improve C# Performance Using Struct Instead of Class Update on the Forge Design Automation API for Revit...
