Hopefully this topic won't get busted with the moderator approval bug once again (btw Admins/mods, you can delete my thread from yesterday that still isn't visible)
My current project is a real PITA. I've got lots of different situations where I need to use independent wall sweeps for parapet cope/flashing's. The problem is that the depth of them changes and in some cases the profile may change every so slightly but common surfaces still remain between the different profiles. I've tried without success to get sweeps with different to mitre correctly (blue dot's matching/same material etc...) and I really don't wan't to have to create GM families for every single arrangement of profiles.
How do you deal with this?
