Hello. I am trying to place Second Empire-style dormers in a mansard roof. Because the whole dormer is situated in the steep part of the roof, this will function more like a wall cut than a dormer cut, but the wall cut tool will not let me select the roof, and the dormer cut tool gives me the "circular chain of references" warning when I try to complete the cut. I would like for the bottom of the cut to be 1' above the lowest part of the roof, forming a sill that extends horizontally into the roof. Does anyone know how I might do this? Thank you!
Horzontal Cut in Mansard Roof
At the risk of just confusing you, the way I do dormers is to create the front and side walls of the dormer but leave them sticking out of the roof, extrude a short piece of the dormer roof (roof by extrusion) then use the Join/Unjoin Roof tool (outlined in red on the image attached) to extend the dormer roof to the, in your case, mansard roof.
The side and front walls where they intersect the roof plane will allow the intersection line to be picked and trim to complete the lines created by the Dormer Opening tool.
Once the cutout is created you can trim the side and front dormer walls to the dormer roof and then trim the base of those walls to the underside of the mansard roof.
Then copy that dormer along the mansard, making sure to include the opening cut.
The circular chain of references error - not sure but you might be able to lose that by disassociating an extrusion from the workplane.
I hope that is some help but others may have better or clearer suggestions.
Hi everyone
I have a flat roof of a coolroom and I need to do a mitre cut around the perimeter of the roof. How can I achieve that? I tried...February 4, 2017, 03:29 PM -
Is there a way to have Revit automatically cut the portion of the roof out where the roof join/unjoin tool is used, rather than using the roof opening...November 19, 2020, 08:00 PM
Hi guys, I am having a problem with my roof, I am trying to render a view of my house and the problem is that the roof is inside my window, but if I try...December 27, 2018, 03:32 PM
I am joining two roofs using the Modify - Join/Unjoin roof tool. When I join them, I need the portion that is underneath the join to be cut out of it....February 17, 2020, 05:05 PM
Okay, let me try to explain this. I have a gambrel roof by extrusion. Where my cupola's are, the window is below the ridge of the roof. So, I need...August 1, 2012, 01:24 AM
