I have 2 revit files done by different people. I've changed the project base point and survey point to be the same figures and the rotation angle etc to be the same, but when I do copy and paste to current view, the things don't match. Then I read about Revit startup location, and discovered that one of the startup location was on the right side the other file's startup location is at the left side.
My question is : beside using shared coordinates and publish the coordinates to link them, is there any chance that I can reset them properly so they match perfectly from origin to origin?
Thanks in advance.
Thanks in advance.
