anyone experienced? what's the reason or logic behind it? well, kind of wasting time to SWC when nothing is changed at all, it happened just recently, perhaps something wrong w/ model, maybe i should recreate central model?
cannot Relinquish All Mine even if SWC w/ all checked immediately before
I'm inclined to predict an issue with a corrupt family. If you've encountered the error that reports "too many missing elements" then I'd be even more convinced. Creating a new central file won't fix anything if so. You need to track down the family that is corrupt or you might stumble into it when a user tries to place an instance and Revit crashes.
If you find a family that crashes Revit or generates a warning you need to replace it with a version that isn't corrupted. In my most recent case I had to swap out a couple hundred instances (multiple types) with a generic placeholder so I didn't lose the work and then swap the family types back into play based on a version that Revit didn't object to.Last edited by Steve_Stafford; June 4, 2018, 11:30 PM.
Hello everyone.
Lately we're getting corrupt elements in many files at work, which it's getting really annoying.
But there is something...October 16, 2014, 03:14 PM -
all,
"You cannot save this file to the central model. This file is no longer compatible with the central model because same element...November 7, 2014, 03:41 PM -
We've just experienced our first real "O.M.F.G" moment with one of our workshared models - and although we've "fixed" it - I'd like...
Channel: Worksharing and Cloud Coordination
November 17, 2011, 12:27 PM -
As time ticks on into my second week into my new job I'm slowing learning about all that's gone before... and today's discovery has trumped the lot. ...
May 16, 2012, 09:36 AM -
I am having an issue with my Central files for two of our revit Jobs. We are making some minor changes about two weeks after sending out a project. No...January 30, 2012, 05:58 PM
Monumetric Footer In-screen
