I've been noticing this with 2018.3 both at work and on my home machine. I like to run Revit on the left screen, and when maximized it will sometimes "bleed" over by 10 or 20 pixels onto the left edge of my right screen. Clicking the middle "Restore Down" button and then the Maximize button again fixes it, for awhile. Then later it will happen again. It's a minor annoyance I guess, but it is indeed an annoyance especially when the Revit window covers up the edge of content on my right screen whenever the Revit window is in focus.
Has anyone seen 2018.3 "bleeding" over onto a 2nd monitor?
Originally posted by PatrickGSR94 View PostI've been noticing this with 2018.3 both at work and on my home machine. I like to run Revit on the left screen, and when maximized it will sometimes "bleed" over by 10 or 20 pixels onto the left edge of my right screen. Clicking the middle "Restore Down" button and then the Maximize button again fixes it, for awhile. Then later it will happen again. It's a minor annoyance I guess, but it is indeed an annoyance especially when the Revit window covers up the edge of content on my right screen whenever the Revit window is in focus.Last edited by Andres Franco; May 29, 2018, 02:23 PM.Andres Franco - Architect - BIM Coordinator
E.A Poe
This may be a whole separate issue, but we've been seeing a lot of users getting trails left on the screen when dragging the Project Browser or Properties dialog.
Autodesk is blaming it on the Windows 10 Fall Creator's Update
Users reported that since the Windows 10x64 Fall creator update (build 1709) was installed, Revit dialog boxes leave trails when moved across the screen. The Properties palette and Project browser appear to stutter or flicker when moved. The behavior is visible on the following video
No fix for 2018, they do say it's fixed in 2019Dave Plumb
BWBR Architects; St Paul, MN
Also, if i have the revit window maximised i sm not able to click and drag the window by the title bar. I have to double click the title bar to make the window minimise then drag it. This happens only in Revit 2018, all other programs work ok.There are no stupid questions, only stupid people
Originally posted by DaveP View PostThis may be a whole separate issue, but we've been seeing a lot of users getting trails left on the screen when dragging the Project Browser or Properties dialog.
Originally posted by elton williams View PostAlso, if i have the revit window maximised i sm not able to click and drag the window by the title bar. I have to double click the title bar to make the window minimise then drag it. This happens only in Revit 2018, all other programs work ok.
Originally posted by PatrickGSR94 View Posthaha luckily I use Win7 both at work and at home. I'm not sold on Win10 AT ALL.
huh weird, that works fine for me on 2018.3.
Aaron Maller
Director
Parallax Team, Inc.
Originally posted by Dave Jones View PostI vote for this as the Understatement of the Weekend!
Factor in the SMB3 issues, and the fact that Autodesk hasn't updated their start menu deployment methodology since win7, and win10 can really be a big pain.
But... Every now and then I go to a client's office still on win7, and it's so brutal. I count the minutes til I can go back to my own machine. Hahaha.
Aaron Maller
Director
Parallax Team, Inc.
We have four interface problems that occur regularly - not all the time, just now and again. But once they start, the only way to fix them is to exit...February 28, 2013, 02:44 AM
I can't believe I'm still having the "Jumpy Screen" problem in 2013.
I'm talking about the one where the Options Bar doubles or triples...September 5, 2012, 01:45 PM -
Hi!
I just started at a new office and they gave me two different screens, one with recommended settings 125% and 2560 * 1440 resolution, and the...January 15, 2018, 03:20 PM -
Hi all,
Anyone using the Autodesk Remote Utility?
I was able to get it to connect to my workstation from another workstation,...-
Channel: Out There
October 18, 2013, 06:34 PM -
I've never put much thought into my monitors, I have a 15" laptop with a 22" monitor and initially thought I'd just get a second 22" monitor...December 16, 2020, 12:32 PM
