I have a partition wall that I need to double the thickness of in scheduled thickness of our wall schedule. When I put the formula in it deletes the units because I am neutralizing the unit for calculation. How do I get the units back?
losing units in formula
Change your calculated value from a number to a Length parameter and you should be good.
edit: that will involve deleting your current parameter and recreating it.
edit2: cliff's response (below) is way better than mine.Last edited by cellophane; May 18, 2018, 06:29 PM.
Cliff this is a response to workflow. In order to do apartment units as groups we do the partition wall as a half partition wall. In order for this to schedule the wall properly I need the full width of the overall partition which will include both instances of the wall. So no I will not ever use the full width of the wall. I don't want a rogue wall sitting out in no mans land just to schedule it.
Am I missing something? To just multiply the width of a wall by 2 you do not need to "neutralize" the units. Just straight up multiplication will work just fine.
EDIT
Oh I see this was already proposed. You are setting the format of the calculated value to "number" that is what is making it need to be "unitless". You don't need to do that. You can just set the calculated value to be "length" and then the math works just fine.Last edited by JeffH; May 18, 2018, 06:55 PM.Jeff Hanson
Sr. Subject Matter Expert
So--it's a party wall or demising wall, so you are counting "half in one unit" and "half in the other unit"?
That's one "workflow". But I have done many of these types of projects, and we just scheduled the actual modeled walls, and got the GC/CM involved early to explain our quantification method.
But, it looks like you have a solution for the formula in the schedule.Cliff B. Collins
Registered Architect
Autodesk Expert Elite
I am trying to make a schedule but can't get it to work.:banghead:
I want a formula in my schedule that calculates the number of panels in...May 4, 2016, 10:40 AM -
Inconsistent Units ! Probably THE error box in Revit that have caused me the most grief, over the years I´ve spent hours and hours on trying to work...
Channel: Tutorials, Tips & Tricks
March 31, 2011, 09:53 PM -
Is it possible to create units for parameters. such as lbs/hr or MBH?
Channel: MEP - General
July 9, 2014, 06:55 PM -
I'd like to have our Steel Framing families do a couple of extra calculations for us to handle 1) Preferred Orderable Increment rounding 2) Unit Conversion...
July 6, 2016, 01:45 PM -
Is it possible to connect text in a formula? I'm made a schedule, that gives a unit to my items, but I want to make a new column with a formula that connects...May 27, 2019, 07:54 AM
