How would somebody go about modeling something similar in concept to this picture? It's a metal skin that will be attached to a standard steel frame. My guys aren't particularly well versed or skilled in using adaptive points so if that can be avoided great. If not, well then we'll have to learn.
Modeling a multi faceted wall
Mass it up and apply walls by face.... how you create the mass, well, that's a different story.Greg McDowell Jr
about.me/GMcDowellJr
A series of blends, where the top and bottom sketches have different numbers of edges, create a shape very similar to that. Then you simply grab some of the points and adjust them in the Z direction.
But, before i would know how or what to use to start creating those blends, i would want to talk to the designer about how they came up with where each of the vertices are. If their answer is something goofy like *its random or i nudged them* it makes the job really freaking easy. If they are in a series of very specific locations, understanding the logic of the arrangement first, is paramount to picking a direction for modeling logistics.
Originally posted by Twiceroadsfool View PostA series of blends, where the top and bottom sketches have different numbers of edges, create a shape very similar to that. Then you simply grab some of the points and adjust them in the Z direction.
But, before i would know how or what to use to start creating those blends, i would want to talk to the designer about how they came up with where each of the vertices are. If their answer is something goofy like *its random or i nudged them* it makes the job really freaking easy. If they are in a series of very specific locations, understanding the logic of the arrangement first, is paramount to picking a direction for modeling logistics.My ID was stolen. Now I'm only called Dav
Hello again ...
I had to post it again!!! NOBODY KNOWS THE ANSWEAR GUYS???????????????????????????????????
I want to join a...April 19, 2012, 07:04 PM -
Hi every body,
I have made a form with conceptual mass and I just want to give wall face to a part of its face. Is it possible?June 17, 2016, 03:26 PM -
So my intent is to use in place mass for representing existing walls with varying sizes from the site survey for a project that will be demo'd later....May 24, 2017, 08:46 PM
I created an in-place mass where I joined 3 masses. I want to create walls-by-face in order to schedule this object, but when I attempt it, revit creates...August 1, 2017, 05:13 PM
Is it possible for the ends of walls to flex with a mass, rather than their face? Eg. attached, where the wall is perpendicular to the mass surface which...March 3, 2012, 06:26 PM
