How to export all the Revit data to an external database?It is very simple to extract all the parameter data.Let's implement a solution to do so Existing sample implementations Black box input Choices for the output and its structure Retrieve parameter values from an element FilterCategoryRule versus category filters Category description extension method Retrieve parameter data for all elements of given categories External command Execute mainline Sample run results Download...
