You could try using reference lines in the family, with an angular dimension. Load into project. Adjust angles of supports.
Is the support a Generic Model? Perhaps if it was a Baluster family it could adjust to the slope of the railing?
When in railing sketch mode, you'll have to split the railing line where the bracket is being located, then select the segment & on the Options Bar select from the "Slope" Options, one will say "Flat". Maybe once you split it at the Bracket location it may then relocate it. In such case I'd just duplicate the railing to only show the brackets, then remove them from the original type.
ok, this is prompted from a pervious thread
This is one for those who hate railings and balusters. Have a play with this railing and let you imagination...
HI everyone , i am building families for a stair and railing company whick so far i add everything made up but the hardest part for me right now is to...
I am trying to customize the railing as per our design, which in fact seems quite simple. But I am unable to change the radius of the handrail and post...
