I have done everything I can think of and tried searching for answers. I am working on my underground waste system. I have two locations with the same toilet and sink. I can not get the sink to show up on my plan view. I have attached a screenshot of the bathroom, you can see the domestic, and waste pipes that connect to the sink but no sink. It is a downloaded family but the confusing thing is that the toilet came from the same source and it works fine. Any help is greatly appreciated.
Missing Sink
Originally posted by evan.dodds View PostDid you try going into the family and seeing if the 3D geometry is marked to show in the views/resolution that you want? I usually find the manufacturer plumbing fixtures to be the jankiest in how they are modelled.
Plumbing Fixtures dont show if they are under the Cut Plane of a view, even in Mechanical views.
A really stupid feature made for architects.
Means that if you have plumbing connections up high or in a ceiling you need to set the cut plane higher (So doors wont show in the walls...)
Or you can put extra reference lines in the families so they extend down through the cut plane, but then you might have problems if someone places the same family on the floor and it appears on the level below."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Originally posted by josephpeel View PostPlumbing Fixtures dont show if they are under the Cut Plane of a view, even in Mechanical views.There are no stupid questions, only stupid people
Originally posted by elton williams View PostNot sure I get what you mean here, I use plumbing fixture category families all the time that are well below (900) my cut plane (12-1500) and they show up just fine?
Haha. I meant they ONLY show if they are UNDER the cut plane... :hide:
I think the op got what I meant.."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Hello,
I could do with a bit of guidance on how to create plans.
Firstly I set up an Elevation a 3D section & a Plan view...March 15, 2013, 09:14 PM -
Hello again. Sorry for the sudden bombardment of questions, I really hope everyone doesn't mind. I will try to save the questions as much as possible...
Channel: MEP - General
May 20, 2011, 08:05 PM -
I downloaded a Revit family from a manufacturer's website and it's exactly the one I want. It is a piece of specialty equipment. In our equipment plans,...March 11, 2019, 01:54 PM
Hey all,
It's me again!
I tried to draw a pipe on a plan view and revit gives me a warning that it is not visible with the settings I have....-
March 18, 2011, 11:59 PM -
In Revit 2019, is there a way to "show in view?" Like the opposite of "hide in view?"
I have a plan that has a steeply...August 15, 2019, 02:43 PM
