Our team are working between Revit and Inventor on a curved ramp project.
The architects (including me) are using Inventor to model the curved walls and ramps (because the geometry is too complex to be easily build-able in Revit), the Enginners are modeling the stepped concrete foundations in Revit. The Engineers want to import our Inventor file into their model, to take levels and dimensions from it. To do this currently, they are exploding it, which looses some of the geometry. The message pops up: 'Import contained some 3D data or points which can't be exploded.' and some curves disappear from view. Screen shots attached.
Does anyone know, please, either a way to take levels or dims without exploding; an alternative method of importing (e.g. some kind of mass file that will allow all the geometry to be seen and measured); or some other helpful method that means we can work around this issue?
I am not an experienced Revit user, my expertise is limited to opening or importing things, moving them around and following instructions. Both on 2018 software. Any help gratefully received.
