2018: Offset inside Sketch
    Had a user report this and I can't test it right now.
    Has anyone else seen this?
    Can you confirm a bug in 2018? If you draw a filled region and finish sketch, then go back into the sketch can you offset the lines of the sketch with ‘copy’ unchecked? I can’t.
    Dave Plumb
    BWBR Architects; St Paul, MN
    Dave, I'm on 2018.2 and it works fine in the project environment and the family editor in a generic annotation.
    EDIT - This is what I get:
      Thanks for checking.
      I got a chance to check this morning, and I'm working as expected, too.
      Maybe Pete is either cursed or imaging things.
      Knowing him, it could be either.
      Dave Plumb
        No problem, happy to help.
