I have a building model, I have a site model. Both started with the same project template. The building is modeled project north straight up and the site is modeled project north and true north straight up. The site was then linked into the building, then the site model is rotated to the orientation the designer wants the building to sit on the site. Now we want the site plan in the building model to show true north. So I select "acquire coordinates" and select the site model and get a message that the models allready share the same coord. system. But it won't show true north. What am I doing wrong. If I pick on the site model and click shared it shows "record position of this model" so it wants to publish to the site model. Whats up?
Acquire Coordinates - Model and link share same coordinate system allready
Scott D. Brown, AIA | Senior Project Manager | Beck GroupTags: None
I believe it needs to be the other way around where you set the True North in the Site, then in the Bldg models acquire coordinates from Site Link, or link in the Bldg models into the Site model & "Publish Coordinates" once you've located them, but make sure no one is in those files when doing so for ease. So each building should get it's own Internal Point Name assigned, like "Bldg A", then "Bldg B" when you "Publish".
You could go to AU classes for more in depth procedures.Last edited by cftrevizo; April 24, 2018, 03:48 PM.
Originally posted by sdbrownaia View PostI have a building model, I have a site model. Both started with the same project template. The building is modeled project north straight up and the site is modeled project north and true north straight up. The site was then linked into the building, then the site model is rotated to the orientation the designer wants the building to sit on the site. Now we want the site plan in the building model to show true north. So I select "acquire coordinates" and select the site model and get a message that the models allready share the same coord. system. But it won't show true north. What am I doing wrong. If I pick on the site model and click shared it shows "record position of this model" so it wants to publish to the site model. Whats up?
The "check" for "Do we share the same coordinates" is more looking for "Is that a file i had the same coordinates as, at some point previously," but it doesnt actually compare current and previous coordinate systems, which sucks.
Been this way forever, im pretty sure.
Originally posted by elton williamsDid this work? I have a similar issue on a current project where some buffoon has unclipped and moved the PBP.
Originally posted by Steve_Stafford View PostMoving it un-clipped does nothing (to the coordinate system it is related to). It's the best possible outcome if someone moves it. Moving is Clipped is when things get messy. If it is unclipped, just right click and choose Move to Startup Location.
Apparently copy/ paste elements works fine between structure and facade but for the interiors model, stuff will paste some distance out in space. Not sure yet if that distance is the same as the difference between PBP's.
I only managed a quick review yesterday when this was brought to my attention. All 3 models "look" like they are lined up when viewed in any of the 3 project files.There are no stupid questions, only stupid people
Hello all,
I would like to ask you what workflow do you use for the toposurface. Do you create it in a differnt .rvt file and each time that...September 3, 2018, 02:13 PM -
Anyone out there ran into this problem?
Setting up shared coordinates. I have a site revit file, insert a site cad file (positioned to auto-origin...November 6, 2013, 04:25 AM -
So the title basically explains my question.
I have two buildings Building A and Building B. These buildings form one overall project on a single...September 4, 2017, 07:17 AM -
I've not written anything about Collaboration for Revit (aka C4R) yet. It's a recent development that puts a project in the cloud to give a project team...
Channel: Blog Feeds
April 12, 2015, 06:15 AM -
Could someone help clarify how the shared coordinates work when it comes to receiving say an architectural model through an email from a client, then...
Channel: Coordination Tools
April 22, 2015, 01:11 PM -
