Family is scaling automatically!!
    Hi Guys,
    Today I'm experiencing some weird issues with my Revit 2018.3, since for the text crashing in Revit there are no response, I hope for this one some of you can enlighten me.
    I have a Family which I've made, a very simple family actually for one of our interior projects, that family worked normal till today, the issue is that the family in the project seems to have different values than in the family editor and more bizarre that family have different values between projects (see images)
    I've already used this family for several projects with zero problems, and I don't know why it seems that in this project the family don't want to have its actual values.
    I've already checked the Units in both projects, the units in the family editor, as you see in images 1 and 2 the values are different even if it is the same object, some of you have experienced this before?, regards
    E.A Poe
    Hi again,
    I've solved the issue!! finally it was a parameter!!, weird since I haven't created parameters for this very simple family but well what can I say there are always some weird things by changing between Revit versions :hide:, regards
    E.A Poe
