Hi all,
I have downloaded a DWG Model from a manufacturer of a chair I want to include in my project.
The DWG is built correctly - Each layer represent a material, and when I import it and adjust the materials via the Manage>Object Styles button inside the family editor everything is fine.
However, when I import the family in the main project, there are no materials. Even if I directly import the DWG, the changes I make to the material assignments in the Object Styles have no effect and the chair remains grey.
I know native format is a far better solution, but the chair is complex and I won't be able to recreate it myself well enough in Revit.
Please let me know if you have a tip that can help me!
Thanks in advance
Thanks in advance
