Cast in place stair.
Am I wrong or the Cut mark type under Graphics options is not following the scale.
I created different Cut mark type each for a designate scale, then when I need to print the set, I need to
print sheets each by each and in between select the stair, change the Cut mark type and proceed to the next.
I imagine you (the Community) have found something better , I appreciate your input.
Cheers.
p.s. probably has been touched before but with so many stair related issues I have not found the specific thread
Cheers.
