Some views not showing i Autocad from Revit export.
    I'm trying to export a sheet to dwg from Revit.
    Some of my detail views on the sheet will not show in paperspace. The viewport is showing, but the content (detail) is not.
    I've got a total of 8 details on this sheet, but only 5 showing.
    In modelspace, everything appears.
    Does anyone have a solution for this?
    Thanks.
    Thanks.
    What are your export settings please?
    E.A Poe
      Hopefully, this is what your asking for.
        yes I was talking about that, sadly I've noticed that you've already unchecked the default export options, did you already check the dialog box that follows? I mean after validate you'll have another dialog box that allows you to export the views in the sheet as external references, I bet that it can be that!!
        E.A Poe
          Tried both options and still no luck.
          A colleague of mine suggested it might be because the three details not showing were projected upwards. May this be the cause?
            Honestly I don't think so! but for the sake of this thread we need to check all options, so another question that happens for all your Sheets/views?
            E.A Poe
              No, this is the first time it has happened.
