Hello everyone,
i've hit recently a Problem with exporting a IFC from Revit. I'm using a selfmade Door Family and when I do export my Project (.rvt) to IFC the door gets centered to the middle of the model and not to the middle of the door opening (which it should). Please check the Screenshot. I tried to adjust the door to make the problem more clear. So basically the IFC is moving the door to a spot it shouldn't be.
Is there a way to tell the IFC export (settings) to export the door at the point where it is placed?
I hope someone can help.
Thanks!
Sincerly your
revitnoob
Thanks!
Sincerly your
revitnoob
