Topo sources in Revit
    I'm look for different ways to bring topography into revit. Basically any source will be high enough quality for our current purposes. Here's what we're dealing with:
    • Client is developing a small ski resort
    • Client has provided lidar scan of several thousand acres, and is too big for any of our machines to handle
    • Client wants to see structures and terrain in Enscape
    We could send the Revit files to Sketchup and bring in Google Earth topo there, but then we have to fix all the materials. I've looked into ways to bring topo from various sources into Revit, but I'm not coming up with much. I found something about a Globe Link Revit add-in, but that appears to be discontinued. I found CADtoEarth, but that looks to have a somewhat bad rating. Is there a reliable solution available?
    Owen Drafting Technologies
    Kyle Owen - Owner
    You might try this:
    Software per l’Edilizia e Soluzioni per Geometri, Ingegneri, Architetti, Periti
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      why not make the Topo surface in SketchUp then Import into Revit?
      I like to draw my own contour lines in SketchUp by intersecting planes through the import Google Earth Terrain, which will create contours. You could then import these floating contours into Revit and make a topo surface just like if you had a survey CAD file.
      Creating a topographic map can be a huge pain in the neck. If you've ever tried to get GIS data or find a city topographic map you know exactly what I mean....
      or could do something like this
      5 min Revit tutorial. ... Hey all, I made this video a few years ago for a colleague and never meant for it to get 62k views! I'm sorry there was no audio on...
        Originally posted by cliff collins View Post
        Looks promising. I wonder when they'll have an update for Revit 2019 ready.
        https://www.youtube.com/watch?v=dYchj68_hD4
        I've seen a couple work-arounds using Sketchup that look pretty simple. Now if only we had Sketchup...
        Kyle Owen - Owner
          if you're really in a pinch the 30 day free trials of SketchUP always help!
            If you have the Design Suite with Navisworks, it has a dedicated toolset for Google Earth.
            We needed to import our Revit model into Google Earth, and used this tool and it worked great.
            I think we exported an .fbx from Revit, imported into Navisworks and dropped it into Google Earth.
            Cliff B. Collins
              Not really in a pinch; This project has moved at a snail's pace over the last couple of years.
              Navisworks Simulate or Manage?
              Kyle Owen - Owner
                Manage for sure, not sure about Simulate?
                Cliff B. Collins
                  civil 3d- create dwg topo from point cloud
                  import dwg to revit and create surface from that
                  William Fletcher
                  IPD Engineering
                  Linkedin
                    Next point on Revits 'roadmap' is called "Site Collaboration with Civil3D'.. Let's just wait and see.
