I'm probably overthinking this, but is there a way to have a wall sweep for a shape (in this case a cast watertable) that will also cut out the wall below the sweep for grout / steel angles, etc? I know in sections I can use the View--> Cut Profile function to clean it up there, but then I'm left with a sliver of wall between my sweep and top of the opening that shouldn't exist. It is just big enough to actually see it on the elevations.
Masonry Wall Sweeps & Space for Steel Angles
It used to be when you added a wall sweep to the wall, it would automatically cut at openings and if you need to adjust it further there were little blue...April 12, 2011, 01:08 PM
I'm having trouble with a wall sweep at the bottom of my storefront not cutting. The sweep works fine anywhere else along the height of the storefront...June 24, 2015, 03:25 PM
Hey all,
I've added a wall sweep for my top plate, but want to know if there's a way to add the lumber "cut lines". Aside from creating...November 19, 2015, 04:38 PM -
what is the difference between cuttable and cut wall options in wall sweep?September 29, 2012, 10:39 AM -
I created a family for my drop box. The family only cuts the sweep where the trim around the box is. The center doesn't cut. I used a void for the...
January 20, 2011, 04:50 PM -
