Is there a method for adding a calculated value to a foundation or floor tag, or spot elevation tag, that calculates the over excavation depth"? For example, we need to indicate the elevation that the excavator needs to dig beneath the footing's bottom elevation, if the bottom of the footing is at 10' elevation, and we need to excavate a foot lower, 9' elevation, is there a way to calculate this in the tag?
Foundation and slab tag that calculates over excavation level
I'm not sure if this is what you're looking for, but Steve Stafford had a post about adding calculated values to tag families. I think it's only available in Revit 2017 and later, though.
Revit OpEd: Revit 2017 - Calculated Values in Tags
When creating a footing (or other elements) Revit gives the bottom elevation. Is there a way to get the top of elevation to read in a tag LIVE? We have...July 12, 2011, 12:55 PM
Hi could someone take a look at these images and the family i have added?
When i create a foundation slab at -900 from the level it actually...-
Channel: Structure - Family Creation
August 2, 2011, 12:12 PM -
Has there been any new methods to achieve this? Most of my research into finding out how to tag this leads to comments that say "sure would be nice...
March 19, 2014, 05:05 PM -
I have confused the heck out of myself on this one. Currently, my firm tags the storefronts with a new elevation tag in the plans, and then hides the...
March 20, 2021, 04:55 PM -
I thought you could tag the top of footings in Revit 2016. I have two projects that have pile caps and one project that has spread footings. The projects...
June 19, 2017, 07:29 PM -
