Polar coordinates to x/y/z coordinaters
    Hello folks,
    Has anybody tried to transform with Dynamo cartesian coordinates (I do not know how you called X/Y/Z in U.S) into polar coordinates (which is the table that Revit can read) to draw property lines within Revit?
    If I watch...I dream, if I listen...I think, if I do ...I learn.
    blog
    A first try into transform coordinates
    I gave it a try but I encountered the" Null value cannot be cast to Int32."
    I am using Revit 2017 with Dynamo 1.2....
    First I have to move the origin to something real n the file since the survey was pointing at zero somewhere...else.
    Ideally teh graph will terminate with Revit read an excel file to create a property line.
    blog
