I am trying to use Design Review to see changes between my CD model and my Rebar Detailing model, rather than using Copy/Monitor. When I bring in my DWFx of the one, it will not let me bring in an other for the compare. What am I doing wrong? OR does anyone have suggestions on using C/M? I like the auto updates that C/M would give me, but I am not sure how I can track which elements I am monitoring so that I can be sure I am monitoring all the correct elements.
Design Review
Any chance you are using NewForma for office data management? It has a pretty nice compare tool, which will compare two PDF images, and even create a (GIF based! :crazy: )
Revit can only compare a DWF of a sheet with that same Revit sheet. Totally useless for any other use. Now, if you have two totally different models, you could link one into the other, then set the link in a particular view to look like a particular sheet in that link model. Perhaps changing the colors of the linking model in that view to aid in visual coordination?
Kinda grasping at straws, as there is no really GOOD way to do this. As in printing both and taping them to a windows is just about as good as the digital options.
Gordon
ADR has issues when comparing dwfx for some reason. I have found with minor testing that there are crashes and/or incomplete sheets.
Originally posted by Gordon Price View PostTotally useless for any other use.
When 2 sheets are identical in scale and no details have moved, ADR will show you what has been added and what has been removed. When this is not the case, all information from each sheet will be present as a 'markup' layer. These layers are moveable and re-scalable, and can be repositioned over each other to see the differences. As ADR doesn't support layer order properly, the last selected markup will be the front markup. Knowing this, you can select either markup to switch between revisions.
I have uploaded a manual for basic 2D.dwf use here if it helpsI used to be high on life, until I realised it was cut with Morons.
Combating ignorance daily through learning.
Does anyone work with Design Review for markups/comparison etc.?
I'd like to start using it more for communication between consultants...-
Channel: Coordination Tools
January 30, 2011, 06:34 PM -
I'm writing about both the process and the software. Autodesk has been shipping Design Review along with the rest of its products for many years now (though...
Channel: Blog Feeds
March 3, 2012, 06:45 AM -
So I'm trying to figure out how Design Review works. And I've figured out a few things.
1. you can add the markups (text, lines, clouds, whatever)...-
January 26, 2011, 03:11 PM -
I'm looking for information on the definitive workflow and setup for coordination between architecture models and Structure and MEP files.
When...December 21, 2010, 11:12 PM -
The question is really simple.
I have a design that is the "actual state" of the building.
In the 2D DATA i need...December 31, 2020, 08:11 AM
