I want a Yes/No parameter called Use Sheet Date, which will then drive two more parameters; sheet date visible and project date visible. The key is I want to be able to schedule Use Sheet Date so that the a schedule can be used as a project management tool, so Use Sheet Date must be a Shared Parameter. Of course you can't just add an SP, you have to tie it to a label, but not to worry I can make the label invisible. However, the formulas seem to break. I can't seem to set sheet date visible = Use Sheet Date. I get a not valid parameter error. :banghead:
Another tree that isn't worth barking up I suspect? Alf, any nifty tricks? Seemed like such a good idea when I had it.
Gordon
Gordon
