Has anyone used the "Design to Fabrication" tool inside Revit to convert generic Revit duct to Fabrication parts? I am using Revit 2018 and it doesn't seem to be working. Any suggestions would be appreciated. Thanks
Revit Design to Fabrication tool
I discovered an issue with it not filling rediltee the way my button mappings were set up, so that is a known issue. I had it set to use a lateral tap (hole cut in the duct and the tap screwed to the duct body) but Revit insisted on using an actual full-bodied tap fitting (duct barrel body and tap all-in-one).
My high efficiency taps were never "connected" to the main either. Never resolved that issue. May be in the ITM somewhere...
Hello, would anyone know where to start in creating a duct take off per each joint being used, and also represent those joints on the drawing. Our joints...
Channel: MEP - General
December 27, 2016, 11:49 AM -
Hello,
I am wondering how many other people using Revit for duct fab?
I am working on my first full Revit duct fab job and I am wondering...-
June 6, 2017, 07:57 PM -
hi all
I need to create rectanguler flange duct
I am new in revit mep
I-
March 28, 2017, 07:34 AM -
Hello guys and girls. This is my first post ever.
I work for a duct fabricator/ installer and we were previously using CADmep 2015...-
March 5, 2018, 04:19 PM -
Hi
Please can someone advice how to create a system type using fabrication mep parts.
If I create a exhaust or supply air duct duct from...-
October 19, 2018, 05:32 PM -
