Maybe we can spur up some discussions. There are two things I look at from a set of contract documents, and 9 times out of 10 they're a problem.
#1 - Upsize your ductwork for internal liner, and apply the liner. Add external duct wrap to duct accordingly. Account for an additional 4" overall for flanges of larger or medium pressure ductwork.
#2 - Slope your roof drain piping.
Regarding #1, here are some tips: hide Liner and Insulation categories on your sheets, using these extra items in working views to help coordinate areas better. Use a "Free Area" parameter for duct tags to keep the duct sizes correct for lined ductwork.
In recent years I've seen some MEP firms produce some decently coordinated projects. While the attempts are very much appreciated, these two items above still wreck shop in tightly coordinated areas. Making the above two items an absolute and mandatory design standard in an MEP office can - and will - reduce so much RFI and change order issues during the CA process. When you run duct and simply spec the insulation requirements you're simply setting yourself up for failure. When you run roof drain piping horizontally and don't slope it, again, you're setting yourself up for failure. These few items are literally easy-buttons in Revit.
Hope these tips are found useful. I've seen too many projects, with a decently coordinated Revit model, go through extensive RFI processes and angry architects due to dropping ceilings and shifting walls. It's pretty much almost every project. Architects, make note as well - you guys and gals may want to require these items from your MEP firm if you are in the position to set such a standard among the team.
-TZ
-TZ
