I am not sure why, I checked my visibility settings, and there is not a plan region here?! the jambs in the same doors below are showing~? any advice greatly appreciated !
Door Jambs not visible in Floor Plan
Too many unknowns to hazard a guess. Could be instance based visibility parameter in the family? Detail linework representing the jambs instead of 3D geometry? Some geometry in the model masking it from view? Is the offset of the door below the floor level (this could impact detail linework in the family)? Is this the identical family as the one across the hallway?
Can you upload a trimmed down version of that model for review?
Jonathan Ludwig
Studio 111
There is a list of 32 reasons (link) why something in Revit might not be visible and any one of those can be it. But as Jonathan says above, hard to say which one when we can not have a peak at the actual project.Company Website: www.deurloobm.nl
Originally posted by maddyjdelaney View PostI am not sure why, I checked my visibility settings, and there is not a plan region here?! the jambs in the same doors below are showing~? any advice greatly appreciated !
Sent from my SM-G950F using Tapatalk
Finish floors usually get swings, but if the jambs are done with lines instead of modeled (modeled turned off in plan) a finish floor that is higher than the lines are in the family could hide it.
If you select the door in the plan and isolate it does it show correctly?Julie Kidder
Architect + BIM Director
I feel I have ran into this before, but i forget how to fix it, I don't want the gate to be be shown closed in floor plan, I want it to show as open....March 26, 2019, 11:16 PM
Hello!
I am having trouble with my doors showing up on the floor plan view in revit
When i hover over the door it is there as it highlights...January 4, 2017, 06:29 AM -
I'm fairly new at modifying families and would like to improve upon the graphics of the OOTB coiling door. Although the door housing at the top is an...
March 14, 2012, 08:32 PM -
I've been working on a door family for an office building. It was built up over a number of sessions with different functionality added...-
January 27, 2014, 02:17 PM -
Hello
I am trying to remove the lines that show in wall openings (see jpg).
May someone steer me towards the correct settings,...October 25, 2012, 06:25 AM
