I have an issue where our railing doesn't work correctly at the main floor landings but it does work correctly at the mid-landings. This is a multi-run stair condition. At the main landings the railing goes one tread too far so the handrail height end up being one tread too high (right side of section/isometric images). It needs to be the same "gooseneck" type condition that occurs at the mid landing (left side of section/isometric images).
see images attached.
Thanks,
Travis
Thanks,
Travis
