Resetting Staircase Tread Number Tag
    I've been working on a multi-story stair case and I had to delete the stairs and start over. When I tag the stairs with the tread number tag, it carries on the numbering from the previous numbering. So in my case the number begins at 21, rather than 1. Is there any way to reset the numbering? I am using Revit 2018.
    Thanks
    Originally posted by esoe2k3 View Post
    Thanks
    I haven't used multi storey stairs, but with a normal stairs the tread number start is a property of the stair.
    Select the stair, and you should see that property, which you can change.
    Sent from my SM-G950F using Tapatalk
