Hello,
I'm working on a project and I'm coming from the field of geodesy. I have following problem:
I have a dwg file of a builing which is built. There are uneven rooms, the angles are not necessarily orthogonal and so on. What is the best way to model the geometry of an existing builind which is that "uneven"?
And when I eventually have modelled the builing what is the best way to compare the model with the exising dwg file? Is there a way to investigate the accuracy of the Revit model? Are there some common ways to detect the accuracy of the geometry in a statistical way?
Thanks in advanced for your help!!
