Several questions on filtering for intersecting elements came up recently.It is pretty easy as long as a bounding box can be used.However, the bounding box is generally aligned with the cardinal X, Y and Z axes.If the containing volume of interest is not, too many elements may be selected Family instances in a diagonal room Conduits intersecting a junction box Generate 2D arc from radius, start and end points...
