We are using Revit 2018.2. Is it possible to export a Revit file to a searchable DWF? It is one of the City requirements. When We've tried exporting to DWF, the file is not searchable and a lot of the text does not translate.
Creating a Searchable DWF from Revit
Originally posted by krickabaugh View PostIt is one of the City requirements
Further, whilst it's commonly accepted Adobe bagged the world's fixed document format (with .pdf) it does seem odd that a public institution would stipulate the considerably less-common, and stricter-proprietary format of (Autodesk's) .dwf. Do not get me wrong, I like .dwf(x) and I know arguing the toss against city/state requirements is often a dead-end battle, but it is just, well, weird.
As for your woes:
Originally posted by krickabaugh View PostWhen We've tried exporting to DWF, the file is not searchable and a lot of the text does not translate.
If by "searchable" the requirements mean/t "navigatable" then yes, Revit can readily produce .dwf (and .dwfx) that enable in-document movement via callout heads - but it does require the bulk-export of a set, which almost always run counter to parallel requirements of one-file-per-document.Last edited by snowyweston; March 4, 2018, 11:28 AM.
For some reason when I try to export to a DWFx/DWF the file is not created at the end of the day. Not sure if there are other settings....August 28, 2014, 03:26 PM -
Are there any size limitations on exporting large files to dwf? We are trying to export 6 x 78 storey towers on a 7 storey podium into one dwf? The export...August 13, 2014, 08:19 AM
Hi Rfo, a question about DWF markups in Revit.
I investigate on a workflow including linking dwf markups, but I can't find a way to tag...-
Channel: Coordination Tools
October 1, 2012, 03:53 PM -
So I'm trying to figure out how Design Review works. And I've figured out a few things.
1. you can add the markups (text, lines, clouds, whatever)...-
January 26, 2011, 03:11 PM -
I have a revit model with revit models linked into it. When i export to dwf it does not show the linked models in the dwf file. Is there...March 13, 2014, 11:50 AM
